So I am setting up a static point with a Reach RS that will have a consistent known point. I used a VRS connection to determine the known point of this static point. While gathering it was able to gain a FIX and no issue.
On a drone I have the M2. Using the same VRS I was able to get a FIX and have no issue.
When I set the base to a manual point and then feed the correction to the drone via LORA it will never go beyond a FLOAT. What am I doing wrong?
M2
Status Page - Image 2020-06-18 at 4.42.20 PM
RTK - Image 2020-06-18 at 4.42.53 PM
Correction Input - Image 2020-06-18 at 4.43.38 PM
Base Mode - Image 2020-06-18 at 4.43.20 PM
Reach RS
Status Page - https://share.getcloudapp.com/NQug15LP
RTK - Image 2020-06-18 at 4.55.47 PM
Correction Input - Image 2020-06-18 at 4.56.10 PM
Base Mode - Image 2020-06-18 at 4.56.29 PM
