I should add that I’m using ReachView 0.4.6 on Reach Image 1.2,
Interestingly, when I go from the Config tab to the Status tab, the mode displays a value of “Rover”, but as soon as the satellite signal strength bars are shown, the field changes to “undefined”.
The base LED is (white) - blue - magenta - green
The rover LED is (white) - blue - blue - green
I would try to do another software update just in case. I’ve had funny behaviours before with ReachView, and I’ll either restart the ReachView server or just reboot Reach.
On today’s try, things just worked! My rover displayed “Mode: rover” and “Status: single” and I had llh values. Next, I entered some base coordinates (I just grabbed a recent lat-long-height reading and used that for now) and it went to float!
Once it was in float, I saw the gray satellite signal bars on the status tab. I’m not sure what that tells me, but we expect to see them, so that was good.
I blipped into fix status every now and then. My skyview is not perfect, so this was not a surprise.
Now, my next challenge - determine what is needed to get faster fix, more time on fix.
I’m using the Tallysman TW4721 antennas on a single sided PCB 15cmx15cm (6"x6").
