My reach rover is sending output data through serial to an arduino device. Format: NMEA strings. I would like to let the arduino check the status of the output (single, float or fix).
In the NMEA GPGSA format, the second part of the string is 1 (no fix) ,2 (2D) or 3 (3D).
However when I have status single, float or fix, the reported number is 3 meaning that I have a fix, which in two of the cases I have not.
Anyone knows why this is & how I can fix ( ) my problem?
I think NMEA FIX definitions are a little different that RTK definitions. RTK uses FIX, FLOAT, and SINGLE + SBAS DGPS< etc. NMEA FIX is more like FLOAT in RTK as original GPS units were mostly single receivers. The 2D FIX came about because NMEA was/is a sea going standard where most GPS receivers were at sea level. I’m not certain or the 3D part, but probably was added for land usage. So, I don’t know the answer. maybe someone is more familiar with the different definitions and NMEA standards.
