I am still using a setup with the old REACH-module and would like to get the time mark pin to register camera-events in the log-data of the module (not to trigger the camera and not using a flight-controller).
But I am unable to find the link / description, how the cabling between the old REACH and a standard hot-shoe adapter was realized.
The camera has to be wired to the old REACH-module directly without a flight-controller.
Does anyone has a link or description about the cabeling?
Please, check out the pinout of the Reach Module connectors, available in our docs. There is a Time Mark pin which could be used to register the moments when the shutter was activated.
The hot-shoe adapter we provide is tailored for M+/M2 devices and won’t work with Reach Module. It’s more likely you’ll need to make a custom cable for this kind of integration. You should connect:
