Sorry if this is a daft question but should the reach module be mounted in a particular direction? I note that it has XYZ on it so do I put the gps on the top with the Edison stuck down flat.
I’m going to be attaching it to a pixhawk and assume that I do not need another gps?
Does reach have its own compass and can I anodized the ground plane plate?
Its my understanding that the reach is sort of independent of any of this. What matters is the antenna and it requires a groundplane. The Reach docs go into this in detail.
You can mount Reach in any orientation. You will need a separate compass, so using Reach as the second GPS is a good idea. Ground plane can be anodized.
Thanks Igor. I’ve found an external compass I can use so will try it with that first and then a primary gps with reach as the second gps unit. In an ideal world reach would be the sole GPS / Compass solution
@Multirotorcraft mind sharing what you found? In the past I’ve used a cheap amazon GPS + Compass that works so so. So far haven’t been able to find much else ready to go solution.
