Hi, apologies if this is covered somewhere else but can’t seem to find any info.
Setting up the Reach system as per the quickstart instructions, but for some reason whichever module is configured as base never shows any sats in the status tab. Both seem to work fine in rover mode, getting plenty of sats and good lock.
Satellite levels are currently not being shown on the base, we are working on this. When you connect your rover to the base, sat levels for both receivers will be shown on the rover.
Thanks very much - does the base station config tab provide base station coordinates from the single solution despite showing no sats?
The documentation states, I think, that in the absence of user provided base station coords the lat/long/alt values will be provided by the base station single gps fix - should this be happening with my units?
One quick question, for Automatic Base coordinates, how accurate will these automatic base coordinates be? Will they be at RTK accuracy, or will there be a deviation? If so, how large?
So how can you tell on the status page which satellites are being detected by each component (Base/Rover)? Also what are the letter assigned to the bars, e.g. G, I etc?
