Hello, it is possible to use data from another base station model to ppk with reach m2 module?
Thanks is advance
yes as long as it can output RTCM3 and you have a way to communicate between the two.
Or rinex
Hi Daniel,
Yep, it’s possible. The main requirement, as Christian said, is that the logs from the 3rd-party base should be in RINEX format. The workflow for PPK in Emlid Studio you can find in its docs.
At the same time, to work in RTK mode with Reach M2 rover and a 3rd-party base, you can rely on @jp-drain-sol advice.
Thank you for the answer, sorry about double post.
