I am using EZsurv for GNSS post processing. I generated two rinex files
Rinex1:Directely downlonaded from Reach M2
Rinex2: Converted ubx to rinex using EZsurv.
When I process with these two rinex files the fix% results are significantly different. Following are the results.
a) EZsurv converted rinex: Fix=88%
b) Emlid Reach M2 rinexL Fix = 31%
I’ve post-processed your files in RTKLib. I don’t see the difference between the results obtained by processing EZSurv converted RINEX and the RINEX converted on Reach.
Below is the result of post-processing RINEX from EZSurv. I’ve obtained 93.2% of Fix with the default settings.
The only difference between the two RINEX files that I can see is that EZSurv-converted one doesn’t have the SNR values in it. Below you can see the EZSurv RINEX.
