Another problem from my side:
When connecting the Reach M2 receiver to the navio2 board, it rarely boots and only orange light is on.
At the same time, the raspberry pi reports under voltage detections. Here two plug in events.
Nov 12 16:30:03 navio kernel: [ 348.011006] Under-voltage detected! (0x00050005)
Nov 12 16:30:09 navio kernel: [ 354.250994] Voltage normalised (0x00000000)
Nov 12 16:31:43 navio kernel: [ 447.851411] Under-voltage detected! (0x00050005)
Nov 12 16:31:47 navio kernel: [ 452.011317] Voltage normalised (0x00000000)
Setup:
- the Navio2 is powered with the delivered PowerModule v2.0
- Reach M2 module is connected via S1 to the Navio2 UART Port
I sometimes get it running by unplugging and replugging it for a few times.
Using a USB Charger it is booting without problems…
Report after attaching it to the power plug
Simple system report
app version: 2.24.0-r0
'wifi_status, interface: wlan0':
- wifi_mode: infrastructure
- ip: 192.168.178.xx
is_added: true
is_connected: true
is_visible: false
mac_address: xxxx
security: wpa-psk
ssid: xxx
uuid: xxx
base mode:
base coordinates:
accumulation: 2.0
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- 0
- 0
- 0
format: llh
mode: single-and-hold
output:
enabled: true
io_type: tcpsvr
port: 9000
rtcm3 messages:
'1006':
enabled: true
frequency: 0.10000000000000001
'1074':
enabled: true
frequency: 1.0
'1084':
enabled: true
frequency: 1.0
'1094':
enabled: false
frequency: 1.0
'1124':
enabled: false
frequency: 1.0
bluetooth:
discoverable: false
enabled: false
pin: '***'
camera:
duty cycle: 20
enable: false
period: 2
polarity: false
constraints:
lora:
frequency:
- - 863000
- 870000
correction input:
input2:
baud_rate: 57600
device: UART
enabled: true
io_type: serial
send_position_to_base: true
device:
night_mode: false
privacy_policy_accepted: true
usage_analysis_accepted: false
logging:
base:
format: RTCM3
started: true
correction:
format: RTCM3
started: true
debug: false
interval: 24
overwrite: true
raw:
format: UBX
started: true
solution:
format: LLH
started: true
lora:
air rate: 2.6000000000000001
frequency: 868000
output power: 20.0
position output:
output1:
baud_rate: 57600
device: UART
enabled: true
format: NMEA
io_type: serial
output2:
baud_rate: 38400
device: UART
enabled: false
format: ERB
io_type: serial
rtk settings:
elevation mask angle: 15
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: 1.0
max vertical acceleration: 1.0
positioning mode: kinematic
positioning systems:
compass: false
galileo: true
glonass: false
gps: true
qzss: true
snr mask: 35
update rate: 5
