I want to install few units of Emlid reach m+/m2 on my drones and would like to have different name when downloading the data, for example: drone1_raw_date.zip
is it possible?
Yep, if you change the name of unit in the settings in will reflect in the files, in RV3, and in the hotspot name.
@wizprod thanks for the quick reply
I changed the device name in the control panel/general settings and it didn’t change the loggings files I download (still raw_date_UBX.zip)
It will only affect new files made after the change of name. Old files will remain with the original name.
@wizprod yes I understand. I changed the device name, disconnected it from power, reconnected it and started a new record… but when downloading it the file was still starting with the same name (raw_date _UBX.zip)
Hi @kubar,
Can you please share the screen showing the name of your device and the Logging tab with the recorded logs?
