Hello,
after a flight with the UAV I’m trying to download the UBX and/or Rinex and it seems that all the data from that session is 0kb in size. Is there any backup I can find for the data?
I’ve logged in with FileZilla in an attempt to download and I get the same results as in Reach Panel.
In panel the size of the files are: UBX/LLH/rinex (the 0mb is the base correction)
In FileZilla:
I also noticed that the logs are smaller in size than before for some reason. Is there any reason for that?
Edit: In the .meta file I got this
{"id": "91376f7a-657f-4d62-8051-74e8a564db33", "name": "reach_solution_20230113085305_LLH.zip", "log_path": "/home/root/logs", "type": "solution", "format": "LLH", "start_time": 1673599985.817819, "recording_time": 3159.757818698883, "raw_size": 445560.0, "size": 65719.0}
but I cannot access root folder.
Thanks!
