I am trying to set up a Foxtech A7R camera (modified Sony A7R) with Reach M+ for PPK.
A diagram of the camera wiring harness is below.
I am powering the Reach M+ through S1 pins 1 and 6.
I would like to know how to connect the hot shoe wires to the Reach.
My understanding is that I should connect the camera white wire (labelled 4. Hot Shoe PPK) to Reach C1 pin 2, and the trigger ground wire (3. Green Cable: GND) to Reach C1 pin 1.
If someone can confirm this or tell me why I’m wrong I would be most grateful- I don’t want to damage my Reach!
Thanks for that information.
For anyone using this particular camera I can confirm that white wire (hot-shoe shutter signal) and green wire from trigger circuit (GND) work correctly with Reach M+ C1 pins as described above.
