Yesterday, I was experimenting on my 2 reach M+ module with External Lora. Base was using the Tallysman Antenna and the Rover was using the Spectra precision Geodetic grade Antenna. The results was fantastics
yes!! and the post process result was solid fix and RTK LORa signal dropout at 2500 m from base. The good this is when LORA signal drop out. You can still post process the logs.
