I use Reach m+ for mapping drone. But just, reach m+ is no-gps (rover : 0). RS+ is not no-gps but reach m+ is no-gps.
Let’s start with all the obvious first:
- have you connected an antenna?
- can you show us some pictures of your setup?
- are you testing with the antenna outside?
Hi Harun,
I don’t have much to add to Christian’s questions so far. It’s essential to check how your M+ with the connected antenna behaves outdoors. M+ antenna needs a sky view to detect the satellites.
Yes, i connected an antenna. Now, i solved. Putting a metal sheet under the gps antenna solved the problem
Harun,
It’s good news! Thanks for the update.
