Can you advise if Ethernet over USB is possible with the Reach M+ as it was with the original Reach.
Regards,
Stu.
Regards,
Stu.
Definitely yes.
Connected directly or does it required a an adapter cable?
No adapter required. Connect M+ with the included USB cable directly to your PC or laptop. In some cases, you may need to provide more power than is available from the USB port, so putting a powered USB hub in the circuit can help there.
