Is that possible to chnage the Setting iof UBlox in Reach m+ ?
I need for example to enable in u-center GPGGA or GPGLL in NIMEA to have a stream like UBLOX MAX6
thank you
thank you
Hi @affar,
Here’s my answer in another thread
thank you
is not possible to change the GPS_14Hz.cmd in RTKlib_config?
if yes how and where can I change it?
It’s possible to set GPS 14Hz in RTK settings tab in ReachView.
But where can I save the new gps14hz.cmd?
Hi @affar,
This repository contains the older version of ReachView that isn’t used now.
is than psossible to downgrade ReachView? If yes may be can I change the cmd to be compatible with my system.
