I might be missing something, but my M+ does not show battery level in Reachview like the RS models do?
How should it know?
If you provide it with usb-power, it is a stabilizer 5V supply.
If provide it with a battery, it doesn’t know the pack-size.
10-4. I have one set up that uses a battery and another that uses USB so I will check that out. Thanks!
Hi @michaelL,
Reach RS+ shows the battery value as it has an internal one. There is no need for such an indicator in ReachView for M+ as it doesn’t have the built-in battery.
