My test was about Reach M (i.e. Reach RTK). Very similar to [Tatiana’s second test] (Troubles with new 2.22.2). Reach RTK was placed on the roof of a car moving around the city. I used a separate mobile Wi-Fi to make corrections from an NTRIP station about 17 km away. After receiving a fixed solution I recorded the raw data in ubx format, basic RTCM with RINEX 3.00 and partly NMEA output, which I changed to LLH.
Comparing RTK and PPK results for this session, you can see the difference in the number of satellites. Hence the request to EMLID to find out the reason for this fault.
2000-02-20.zip (7.2 MB)
WARS0510.pos (277.0 KB)
Further, I explain that the starting point (initialization) I checked in the ‘Survey’
Base Point provides a stream of messages
The content of this thread has been significantly rewritten. I apologize for any inconvenience this may cause.
