I’m using the Reach M+ on my DJI M600 with a Camera mounted on the Ronin MX Gimbal
I also use the Hotshoe to sync the Reach M+.
My question is the use of Gimbal angles from the Ronin Mx and the like… Currently the only in port is the HotShoe into the M+… should I be importing/syncing the Gimbal angles as well through another in-port?
I would have thought having Gimbal angles would have assisted with the Photogrammetry processing, and also scanning of buildings etc in order to generate point clouds.
Reach M+ doesn’t support the gimbal angles import, so it’s not possible to output the data from the gimbal to another Reach M+ port.
Reach M+ can record time-stamps of the photo taken using the Time mark pin. To implement the setup you described, Reach M+ should record the time-stamps of IMU data also, which is not supported by the firmware.
In general, Reach M+ allows obtaining precise coordinates of the photos that ensure good results for Photogrammetry tasks.
