I have recently updated to the reach view 3 app and I keep getting the following message when I try and connect to the reach rover or base, image below. I also have problems with part of the app screen being blocked out and some of the words cut as you can also see from the images. The survey screen has almost a third of the screen missing vertically. Any advice would be great.
You need to update your receiver’s firmware to use the new version. Currently, the stable version is at #27. At Emlid Docs, the version available for download today is 26.4.
I recommend performing the reflashing procedure, due to a very big difference between the versions in use.
