Reach Firmware 29 update brings advanced RINEX logging and extended NTRIP protocols support
RTCM transformation would be great update, excpecialy when neede to stake points.
In Serbia, there is one NTRIP service that provides RTCM transformation ( datum and projection information, 7 parameters Helmert transformation, horizontal and vertical grid shift using bi-cubic i terpolation).
I have tried to use this service connecting to NTRIP using Fieldgenius, but only 7 parameters transformation is applied, no grid shift.
I know that Reach View 2 doesn’t support RTCM transformation for now. Does that limits FG functionality ir not? :thinking:
I think that connecting to NTRIP using FG, and FG applying corrections and transformation to measured wgs84 coordinates will overpass RV2 limitations.
My recent post on this topic
RTCM transformation using Fieldgenius ISSUE
Hello everyone!
Today we’ve pushed a new Reach Firmware 29.2.
This release fixes rare issues related to hanging in Wi-Fi scanning mode.
why does over ntrip not work on 3G?
Hi @agrimgalina,
If 3G coverage is good in your area, it should work. ReachView 3 and Reach don’t know what type of signal you have, it just uses your mobile data. Can you describe your issues a bit more?
I can see that more and more people notice the problem with RS2 work with NTRIP with GSM mobile data download;), maybe eventually someone will spend some time to solve this topic.
This topic was automatically closed 182 days after the last reply. New replies are no longer allowed.
