Hello to all.
I have a problem with DF13 connector, while inserting(with normal pressure) cable to DF13 connector i broke this connector.
Could someone help me with traceout this broken trace.
I will try to solder super timy cable and epoxy the whole connector.
Hi, rinatka7
Dotted-line connections between “plug 1” and “u1” on your scheme are correct.
It will be tricky to repair connection between pins. Good luck!
Thank you very much for help, i hope that i can repair it.
P.S. I want say that quality of soldering is not very good, i mean if it was hard multicopter crash or something like this it is ok, but its due normal hand pressure while i connect connector.
