Hi.
Fond out about Navio and Reach 2 days ago, so I’m kind of New to all this.
Just wonder. Is it possible to use a Reach base station for Rtk with av Topcon system, or are they not compatible at all ?
Kind regards
BjornTore
Hi.
Kind regards
BjornTore
Hi!
Reach base outputs RTCM3 corrections which is an industry standard format. Is can as well accept RTCM3 corrections from a different RTK receiver.
Thanks a lot for the information Igor.
Hi… Did you try to use reach as a base station to topcon steering system??? On a tractor for example…
I want to know how did you do it…
Thanks
Hi.
No I havent done it yet, been to hectic with other stuff, but I just (right now ) thought that I really need to figure this out and get started.
I have no experience with with GPS/RTK in general on the technical level, but I wonder if it would be as simple as using the RX/TX from the Reach -> TX/RX on the Topcon serial input, set the correct baud rate…
I would really like to just buy a pair and figure this out, but on the other hand I don’t want to spend the money if it doesn’t work, and then I end up where I’m right now searching for info, thinking and not getting any progress on the project
Have you done this, or got some information of how to make it work ?
