As we would like to deploy the reach RTK devices in the field already in August, we would like to make sure we have a sturdy casing for each devices. We ordered 8 eight items, so we’d like to look into designing and 3D-printing cases.
Our question: could you provide us with the exact dimensions of the chip and antenna, input ports, switches, and any other info that we need to know in order to 3D a fitting case?
We assume that a plastic casing does not interfere with any of the (GPS, UHF, Bluetooth) signals… have you checked?
I am thinking about going for an everything in one case for the Radio, Power supply and Reach module that mounts on to a standard tribrach which will provide peep hole and leveling. Then a clip on mount for the tripod that holds the antenna and ground plane well above.
