My reach doesn’t boot anymore. It lights blue and flash magenta 3 times, turn off 10 sec and it lights blue and flash magenta 3 times, turn off 10 sec,lights blue and flash magenta 3 times, turn off 10 sec, again and again…
Bad power is what that means. If plugging into computer, try with a USB powered hub.
Also you could try USB wall charger (cell phone USB charger) or a USB power bank.
What battery or power source are you using/trying?
I did try: different power cables and power sources: pc, power supply and batteries… It doesn’t work…
Any others ideas?
Thank you,
PLH
I just try againt and it works now???
So thank you…
I suppose you could try supplying 5 Volt power to the appropriate pins of the DF13 connector instead of using USB.
Also confirm that you tried a USB power source capable of 2 Amp output. And please tell us if you have any power drawing from Reach such as a radio.
If that still doesn’t work, then maybe try reflashing if you can.
Good! I’m glad to hear that.
