I was using my Reachs yesterday, and all went fine. Today when I powered them to access the logs, they create the hotspot, I can connect to the hotspot, but cant connect to ReachView app.
The LED flashes Green and Magenta intermittently. When I could connect before, the LED used to be solid Green.
FYI: For future reference, if the app does not respond for some reason, you can usually ssh in to Reach and salvage your log files before you do the flash.
Flashing will install a clean system, so all the logs will unfortunately be gone.
Green and magenta mean that the device is waiting for a time sync. Without wifi this can be overcome by plugging an antenna and throwing it out of the window for 30 seconds. After the time is synced, the app will start and LED will be solid green.
