I’m using reach RTK module with ReachView v2.9.1-10.
The module is powered with an USB power bank.
I didn’t find in Reachview any information about power status.
Is there a way to check the battery level from a command line (ssh) interface ?
I notice in the doc that the LED blink magenta every 10-15s when the power is low, so I suppose there is somewhere in the linux filesystem a file with battery level.
What you could do is calculate how long your USB power bank will last with a 200mA draw. Then write a timer script which starts at boot and reports estimated power level remaining.
The downside to this is that the script would always assume the battery starts out fully charged.
Thanks !
I wanted to check the battery remotely.
Nevertheless, with 200mA draw end 2500 mAh power bank, it should last at least 10 hours, so It is not really an issue.
