This is a fresh install of the navio2 image, and I have tried different pis and SD cards, strangely this setup works perfectly on my other navio2 board, but not the one I have just received. I have run the update rcio as prompted and this appears to be successful but it still does not work. I would be really grateful for any advice!
Hi Oli!
May I ask you to conduct a couple of tests? This will help me to understand what can cause the issue.
Please do the following:
run
sudo emlidtool ardupilot
stop and disable on boot all ardupilots
reboot Raspberry Pi
run
dmesg | grep rcio
and share its output -
run
lsmod
Also, would it be possible to test this Navio2 with another Raspberry Pi?
