I’m setting up my vehicle using Navio2.
I connected my Radio Futaba T10J + R3008SB to proper slot rail.
On calibration tab of GCS the Radio is shown as 1 channel only.
I reversed my RX to normal (not sBus) and there is no RC signal available… Incidentally, sbus2 output compatible sBus signal to the Navio2… even in no sBus mode…
I will try with my Mac and latest QGC tomorrow (W10 version is OK at home).
Tried S.BUS2 out, unsuccessfully.
Tried to change mode (S.BUS as port 8) from B to A (disabling S.BUS) and change back to mode B (enabling S.BUS), also unsuccessfully
I finally could calibrate the Radio!
Let me tell you guys what are happening…
I’m using UAV Cast software, for remote controlling UAV by LTE network… is a software that easy that task.
When I try to calibrate my Radio after UAV Cast installed, I can`t (the original issue from this post)…
So, I tried to reinstall the Emlid Raspbian image (emlid-raspbian-20191128.img) and setup manually all the system. So, the Radio is recognized successfully.
