Hi Andrew,
Welcome to our forum!
Navio2 only supports PPM and SBUS inputs. Indeed, it doesn’t work with the SRXL protocol. The thing is, even if you connect the device to Navio2 and Raspberry Pi, it still needs additional code development to make it work.
However, as a workaround, you may check if there are Spektrum compatible receivers with SBUS output. You can take a look at the example of it from the older thread:
