Hello everyone
I am developing a specific application for which I need to log the raw files (.ubx) from a reach M2. Maybe Rinex could be an option.
- Turn on the rover, wait 5 minutes, Turn Off the rover.
- Move
The sequence needs to be fairly automatic so I can turn on and off the rover using a relay controlled by a pc.
I was thinking about using auto-start recording and at the end of the day recover the fairly large number of files saved on the M2 memory. ¿Could I lost data due to the fact that I am turning off the rover without pressing the logs recording stop button? (Having to use the phone or web interface is not an option since it needs to be automatic)
I can also try to use SSH of similar. I will be ideal if I could stream the raw data directly to my pc. ¿Any options available?
I have tried to recover the file using ssh but I cannot do that while the recording is running and there is no way to turn off recording via ssh (of which I know)
