Hello everyone.
Here is the string that I use to feed video to my tablet via UDP.
raspivid -n -w 680 -h 480 -fps 20 -t 0 -hf -b 2500000 -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=10 pt=96 ! udpsink host=192.168.8.101 port=5600
How can I change this so that it starts automatically ?
We use systemd to manage services. That’s why I recommend this page to get started. Even though it looks kinda intimidating at first, this is just robust and rigorous. In the nutshell all you need to do:
create a simple service file (for example, let it be raspicam.service) which contains something like this:
[Unit]
Description=raspivid
After=network.target
[Service]
ExecStart=/usr/bin/raspivid -n ....
[Install]
WantedBy=default.target
put it in /etc/systemd/system/
sudo systemctl daemon-reload
to let systemd know of this service
sudo systemctl start raspivid
to test it out
sudo systemctl enable raspivid
to enable on boot
coby
(Coby Leuschke)
April 14, 2017, 3:31pm
3
This is really helpful. One of those things that can save everyone a few hours of google time. Suggest it goes in with streaming dev docs.
panky
(Benedikt)
April 14, 2017, 4:17pm
4
yeah that is really helpful indeed;
i assume rc.local is not being called anymore on boot (as I couldn’t make my scripts start on boot - they work fine on manual start)?
also crontab (@reboot ) didn’t work;
coby
(Coby Leuschke)
April 15, 2017, 4:25pm
6
systemd is now the default service manager in Raspbian since Jessie. caused a bit of a rift in the debian community apparently.
https://wiki.debian.org/systemd
Here is what I did and its simple and straight forward
sudo nano /etc/rc.local
insert the raspivid line before the exit
CTRL X and save and reboot. The camera starts when the Rasberry PI starts
This is a solution indeed but this is not recommended. I recommend the one I suggested above.
Good day again. What is the reason that you do not recommend that method?
What I am a little unsure of is the steps I need to take in the command line to create the service file
I assume i have to create it with something like this ?
sudo nano /lib/systemd/system/raspivid.service
OK so here is what i did
1 touch startup.sh
2 nano startup.sh
Then added raspivid........
3 chmod +x startup.sh
4 sudo nano /etc/rc.local
5 /home/pi/startup.sh
6 /home/pi/startup.sh &
[Unit]
[Service]
[Install]
sudo systemctl dae…
I’d like to point out that the answer has been already given.
I told you I didnt understand that but its ok will ask someone else
As the matter of fact, you did figure out what’s needed. This is the only thing to be done.
