Hello everyone.
I am trying to get raspivid to start in systemd and created the following service file
sudo nano /lib/systemd/system/fpv.service
I placed the following in the unit file
Unit]
Description=raspivid
After=network.target
[Service]
ExecStart=/usr/bin/raspivid…
[Install]
WantedBy=default.target
Doesnt matter what I try raspivid just does not start on boot.
Raspivid works perfect if I start Raspivid in .sh
Hi, Barry
You’ve missed first bracket. Or it’s just copy-paste issue?
Have you enabled the service with sudo systemctl enable fpv.service
so that it starts automatically upon boot?
The bracket was probably just copy and paste.
Yes I enabled it with sudo systemctl.
In case you trying to pipe raspivid to another app your ExecStart option should look like this:
[Service]
ExecStart=/bin/sh -c "/usr/bin/raspivid...... | ......"
OK great ill see if that works. What does the -c do ? and the quotation marks are also necessary?
ExecStart takes commands with their arguments that are executed when this service is started.
Pipe ( | ) is not an argument of raspivid, so the service exited with “Invalid command line option” status.
sh -c
creates new instance of shell which reads command from the following string instead of from the standard input.
Ivan, thank you so much for your explanation
ivan.smirnov:
YES that worked thank you so much
Thank you again for the help Ivan.
Just a note. A side effect of doing it like that is that one can not add -a"text" any more. its not a deal breaker though
