Please mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn’t be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
specify the appropriate category!
ERROR: from element /GstPipeline:pipeline0/GstH264Parse:h264parse0: No valid frames found before end of stream
Additional debug info:
gstbaseparse.c(1155): gst_base_parse_sink_event_default (): /GstPipeline:pipeline0/GstH264Parse:h264parse0
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to NULL …
Freeing pipeline …
Morning everyone and thank you for reading. I have the navio2/pi as well as a pi zero with Raspbian/noobs.
Both cameras works perfectly on the pi zero. When inserting the NOOBS SD card in to the PI/Navio both camares work perfectly. However. When using the cameras with the PI/Navio I get the error messages as pasted above.
How do I fix this?
