Can make changes to the TELEM1="-A udp:127.0.0.1:14550" (input the correct ip) and can connect to a laptop or a tablet. That works now. Not sure what I was doing before. I was doing that but couldn’t connect. Maybe to impatient.
In ardupilot, when I wasn’t connected the Tests all were positive and now Arducopter is running and looks to be fine.
I was having problems with the keyboard not imputing the correct characters, mainly, this one “|”. I was looking at trying to get the camera working. I’ve seen it capture a still image and a video stream when using raspi commands but I’ve not yet been able to stream live video to QGroundControl. Any ideas?
I can ping the laptop from pi@navio:~ $ and there is communication. Camera, i need the camera to be working! Please help me.
I noticed just now that when I make a change to the ip address and save i didn’t automatically get a connection in QGroundControl. I looked at the emlidtool ardupilot and it said connected. I disconnected and then went through and connected and straight away heard QGC connect. I see I will always have to do that. Is that because the Navio2 wasn’t restarted/powered-down?
Yep, did that. If I’m connected to my laptop then try to connect to my tablet I couldn’t. I disconnected the laptop and Navio2. Then reset the Navio2 by resetting the power and then turned on again. With the table running QGroundControl when the Navio fired up it connected. Nice. Not sure on the exact procedure to connect more than one device. But one is enough and it’s nice not having to change IPs.
I have another question. How can I setup the camera? I’m using the wifi from the raspberry pi and my laptop. Is it possible to do that video stream?
I still haven’t set up gstreamer. I just can’t follow exactly what I’m suppose to do. What to do for windows and for android, i don’t know. I tested the pi camera and that works. Took a photo and a video with it. But now what?
I’m just not sure on the hardware side of things, like the wifi nor the setup. Raspberry pi comes with gstreamer installed, doesn’t it?
I’m almost there. Just need to video to work and it’ll be a Killer Setup. Rivalling DJI’s Light Bridge 2 i think so. ezUHF with a good video stream and ground station / osd. Mad fun, if I can get this to work. I’m so excited but this is doing my head in now. HELP ME PLEASE, Some body!
Are you here refering to the auxiliary function switches on channels 5-8?
In the navio2 docs it still says “Auxiliary function switches on channels 5-8 are still not supported and could lead to erroneous PWM generation on motors’ channels.”
I did it, then I changed it back, then i changed it back again. It will remain like this, I guess.
I have a question, actually one or two questions.
If TELEM1="-A udp:255.255.255.255:14550:bcast" allows Navio to connect to different computers acting as a GCS how then could I do the same for the camera’s remote_ip? Using this some how?, 255.255.255.255:14550:bcast
Tested - nothing happened.
Tried to save and run on bootup. Nothing. Not sure what I can do. Any suggestions? Someone has to have had this working. Thanks.
Yes, but, as I’m connected, at the moment, to my home wifi everytime I login on the laptop my ip address changes and because of that I then need to change the host=<remote_ip>. The goal is to have the Flight Controller stream video automatically everytime I power-up. Not sure what I have to do? How are you guys getting the video to stream automatically everytime you turn on the Raspi/Navio2? Do I have to get it so my ip never changes?
