I have some problems, how do I install a new frimware 3.1.1 in mission planner?
As I calibrate my ECS, since there is no command in the mission planner for me to calibrate as some say here in the forum.
if you want to update ardupilot fw you need to put in the following in the command line on rpi/navio as stated in the docs (https://docs.emlid.com/navio2/Navio-APM/ardupilot-upgrade/):
sudo apt-get update && sudo apt-get dist-upgrade
i assume that means you want to calibrate your ESCs?
for calibrating ESCs you need to set ESC_Calibration to 1, raise your throttle on your remote, unplug and replug battery, wait for the beeps from your ESCs, pull throttle stick down and usually ESCs beep again!
make sure value of ESC_CALIBRATION is 0 again afterwards!
