Will NAVIO fit Raspberry Pi B+ ?
We haven’t tested it yet, but it seems that yes - even though the extension header is longer now, it’s first 26 pins are compatible with previous models. On the bad side - mounting holes are different.
Well, I just tested and it works. The only problem is that the B+'s display connector is in the way of the Navio’s PWM header. You can, however, connect it and it just sits a bit higher on the GPIO header.
