How can i export files from QGIS which can be transferred to Emlid reachview.
When i export as .csv with Z-values reachview announces that it cannot be read. I saw that in the structure the position of the ID column is the last but should be the first. How can i change this?
Are there settings in QGSIS?
By exporting as .geojson or .dxf reachview does not work with the data?
I’m not sure this exactly gets what you need, but to continue I just edit the CSV in Excel. It seems to be the easiest way I have found to get exactly what I want.
