Hello,
I wanted to manually control (from my application, without mavlink) the quadrotor with navio controller via c(python) code. So I wonder if it possible not only to obtain sensor information from navio but to get direct control of motors or rc channels?
Thank you in advance,
xFirefly
@xFirefly
Yes, this is absolutely possible. Have a look at our examples’ repository. Specifically, look into Servo and PPM. These should give you an idea how the motors or RC channels can be used.
Thank you for help!
- The Servo code works well, but it actually breaks apm which is not suitable for me.
- The PPM code looks like only decodes PPM messages to PWM.
Is it possible just to make fake RC signal input for controll navio in APM manual mode?
@xFirefly Examples are meant to be run standalone, not together with APM - it may lead to unpredictable behavior.
You can send an RC value to the APM over Mavlink. I’d recommend to try MAVproxy to do this.
http://dronecode.github.io/MAVProxy/html/index.html
Yes, I know this method. But it would be nice if I could avoid using mavlink
