tommy
(tommy@thirdinsight.ai)
September 25, 2019, 7:01pm
1
Running Linux navio 4.14.95-emlid-v7+
I just connected a PX4Flow to the I2C ports on the Navio 2 and I confirmed I can see it when scanning i2c bus.
pi@navio:~ $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – 42 – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – 77
I installed the new firmware as per the wiki (PX4FLOW Optical Flow Camera Board — Copter documentation ) and have re-attached the PX4flow to the Navio2 board.
I have enabled the sensor [FLOW_ENABLE] however my opt_m_x, opt_m_y and an opt_qua values are all ZERO.
Any thoughts on how to proceed?
Hi Tommy,
Have you tried to calibrate the sensor as described in the guide you’ve shared?
tommy
October 23, 2019, 9:00pm
6
Yes, I did do the sensor calibration and it appeared to work well. The lens is focused to about 1m. However, the unit is still not working.
Do I need to specify the I2C address somewhere? Also, I am using the PX4Flow Smart Camera which does not have an onboard sonar sensor. I have added a UART TFMini to my UART port, which is providing elevation data.
Hi Tommy,
It seems PX4FLOW camera can work at 400KHz I2C baud rate max.
I’d recommend trying to lower the i2c_baudrate
parameter in /boot/config.txt
to 400000
. Please let me know if it helps.
system
(system)
Closed
February 8, 2020, 4:28pm
12
