Hello everybody,
I have an EMLID Edge FC and use my Quad X Octocopter Hobbywing ESCs.
I set the servo travel on my Futaba remote control the throttle range: Min. 1000 us PWM and max. 2000 μs PWM. Then I connected all controllers with a cable distributor to the receiver and programm the ESCs with this value. Is this correct, or does one have to use different PWM values when using EMLID Edge?
Thanks for your answers in advance!
R/C setting is correct,
You can verify servo parameters:
SERVO1_MIN 1000
SERVO1_MAX 2000
SERVO1_TRIM 1500
SERVO1_REVERSED 0
SERVO1_FUNCTION 33
SERVO2_MIN 1000
SERVO2_MAX 2000
SERVO2_TRIM 1500
SERVO2_REVERSED 0
SERVO2_FUNCTION 34 …
Marc
