I’m working with Navio2 for a project, but I need more GPIOs
Right now I can only use the UART pins (GPIO17 and GPIO18), but I need more, and I have free PWM outputs, so: Is it possible to use PWM outputs like GPIOs?
Thanks
Thanks
Yep, but only in the next release. If you’re interested we can roll out a beta for you test it out.
Yes, I’m interested, if you can send me the beta I could be doing tests.
Thanks and regards.
I have disconnected the following GPIO from Navio2:
BCM 23
BCM 24
BCM 27
BCM 5
BCM 6
Navio2 seems to continue working without problems. I pass the emlidtool test, and I think everything is ok.
I have tested the PWM from 0 to 4 and I also work correctly.
Doing this can generate any risk?
Is already avaible the beta?
Thanks
We’ll release it later this week!
