Good afternoon, I purchased a PPK kit for the Phantom 4Pro and I am having some processing problems.
I did the step by step as tutorial and gave float result. I couldn’t find the error, so I decided to use an RBMC base to do the test again and it gave a fixed result.
I did the PPP of this base and everything went well, so I didn’t understand why it didn’t fix with my base.
I would also like to know, how do I correct the base?
is it possible to use more than one base in the processing, in the case of RBMC?
What is your base? Have you looked at the satellite graph to make sure all constellations had a good signal? Also, try adjusting your elevation mask slightly.
