I have just unpacked my Navio+ with Pi B+ after relocating house.
I thought that I would do a clean install with the latest image.
Unfortunately things are not as smooth as I had hoped.
The Wifi dongles which previously worked are no longer working
My Huawei Wingle is no longer recognised
Gstreamer does not work as before.
I am getting an error with APT when doing upgrades - libc-bin (2.19-18+deb8u4) is not upgraded/installed properly.
Regarding point 2) above it seems that usb_modeswitch that is installed is very old. It is possible to implement udev rules to avoid the issue.
I removed and reinstalled gstreamer1.0 but now when I try to run it with a script that worked before I get warnings and errors "Failed to load plugin …/libgstlibav.so.
@Gary Hi! New image is created for Raspberry Pi 2 and Raspberry Pi 3. We do not test it with older Raspberries and cannot guarantee that it works properly with them. I strongly suggest upgrading to a new Raspberry Pi.
@Mikhail, I also have an error on startup:
"-bash: /usr/lib/git-core/git-sh-prompt: cannot execute binary file"
Has my image been corrupted or are these errors in the original image? I don’t really want to re-install the image as I have done some work to get the Wingle working.
