We are using a single Reach module together with base corrections from a land surveying service for driving a remote controlled car, but we have had some problems getting good signals.
When the GPS antenna is away from the car we typically get a very good signal (>40% SNR on at least 2 satellites) with Float (and occasionally Fix) as solution status. However, as soon as we keep it near the car the signal drops significantly, to the point where it can’t find any solution.
After some testing we realized that the problem seems to be caused by a USB3.0 hub on the car. Simply connecting a USB3.0-compatible USB-hub almost completely jams the antenna signal (meaning we get connection to at most 3-4 satelites with <20% SNR). Note that we can connect any number of USB2.0 devices with little to no impact and that the wifi connection is unaffected.
Have anyone experienced anything like this? I’ll post a picture of our setup below
The same problem occurs when the reach is powered by a separate laptop. As soon as the antenna comes close to the usb connection it loses the satellites. We’ll hopefully be doing some more tests today, so I’ll try to make a more detailed post later.
This does not surprise me as USB3 operates at much higher data rates. I would try usual EMI cures. Good low resistance grounds. High quality USB3 hub. Added shielding on USB cables &hub. Adding low pass filtering to USB data/power leads,Etc., etc.
Potential multiple causes. Lots of trial and error to solve.
(Isn’t the easiest thing in the world to do…)
Here are some updates. We are fairly certain that electromagnetic disturbances from the USB3.0 hub are causing the issues. We plugged the Reach module into a separate laptop to make sure it wasn’t a power issue, see below:
Our only solution right now is to cover the entire car in tin-foil. This improves the signal by a lot (~50% SNR on at least 3 satellites). We are working on a more permanent solution though…
USB3.0 is known to cause interference with 2.4GHz and GPS. So unfortunately you will need to find a way to shield everything working on USB3.0 or use USB2.0 gear.
