Hello
I want to connecting my Reach RTK to an Arduino UNO to get NMEA position feed into the Arduino.
When I use SoftwareSerial the Arduino receives the messages, no problem. The Reach is powered from the USB port, and the Arduino is powered from the Reach +5V pin. The wireing when useing SoftwareSerial is like this:
But since useing SoftwareSerial limits the baud to 9600bps, I can’t get fast enough refresh rate for my application. Therfore i want to use HardwareSerial, but the Arduino only receives garbage. (Yes, I have set the baud to the same in Arduino and Reach.) The setup for powersupply is the same but the wireing between Reach and Arduino is like this:
When I use my hobby oscilloscope i get these values:
I suspect Arduino can’t detect Reach TX low on the RX pin because the pin internally has a pull up resistor. According to this forum topic there is a 1k pull up resistor.
Do anyone have any suggestions?
Could it be an idea to put in a pull down resistor between Arduino RX and GND? How big should this be?
