persona que hable en español tengo problema con conexion del reachs rs se encuentra en modo hotspot mode no me permite tener acceso al equipo
ok ves a wifi y ahi buscas tu equipo el rover o la base te conecta al que elijas
Autotranslate:
ok you see wifi and there you search for your computer the rover or the base connects you to the one you choose
Can I ask you to clarify your WiFi issue, please?
P.S. This is the public forum, so, please, write in English.
the rover rs does not register in the app fing
the rover was configured to connect to wifi and does not have access to the device.
it is only observed in the fing application
4.I have tried to flash the computer but it does not allow it.
I’d recommend you to watch this video tutorial about the first Reach setup. Hope it’ll clarify most of the points.
If you still have an issue with finding the device after that, feel free to ask here.
In that case, please, provide me with a step-by-step description of your actions.
Thanks.
thanks to the engineer jhon de Bucaramanga I was able to reconfigure the team as well to thank the members of the forum.
