I am using (also) a Reach RS+ as a base and a Reach M+ with Emlid Lora as a rover. Both updated at reach view 2.16.2. using emlid LoRa to transmit data from
Sampling in an open field, in central Italy, in a top of a hill, in a sunny day, the most of the satellite resulted as red and only 4/5 resulted as green.
In particular only 4 GPS and 1 Glonass where green, all the rest where bad received. This happened all morning.
Both the rover and the base suffered from the same problem, so even the RS+ fixed on support at 1m from the ground, and the result was that the position never reached FIX and was always on FLOATING. The AR ratio was always under 2.
And if used in single mode, both give very unsure results (like moving meter and meter from one point to the other)
The Satellite selected were all except BeiDou.
When we used the same configuration before the updating to 2.16.2 everything was ok, and in some seconds we get Fix solution status. But I can’t really say if it was because of the update or not.
Have some other users found similar problems?
Best regards
Stefano
