Since the beginning I’m using Navio2 I’m experiencing problems with the current sense input ADC1 (A3) on the power port.
Actually I never managed to read any value higher than 50 with command cat /sys/kernel/rcio/adc/ch1
or 50mV using the ADC.py source code.
Other users had the same problem with power modules and if it was not a setup mistake or if they
did not changed to another module or even gave up it seems the problem has not been fixed.
I tried with Crius and CUAV 90A power modules, both of them are working on my Pixhawk with correct readings,
but when connected to Navio2 they never shows values higher than 50 on A3.
Voltage sensing is working and shows the correct input voltage of 2.4V for 6S/24V in my case.
I have shorted ADC1 and ADC2 to GND and to VCC (wires from PM removed), A2 and A3 shows correct values of 0V and 5.3V
therefore the analog inputs are working correctly.
If I disconnect the current sense wire from Navio2 then I can measure the correct voltage on it with a multimeter.
I tried to load the PM with 40W and 100W dummy charges, Whatt’sUp meter shows a current of 1.7A and 4.4A respectively
and multimeter shows:
- on the CUAV-PM output 120mV and 310mV
- on the Crius-PM output 50mV and 205mV
When I reconnect the wire to Navio2 it always drops to 50mV, therefore I suspect an impedance problem between
the PM output and the Navio2 ADC input.
Both of these PM are using the common INA169 current shunt monitor IC, the RL at the output are 100K on both.
As Navio2 schematics are not published I measured the resistors forming the dividers on each Navio2 ADC inputs,
all inputs are divided by two with 10K/10K dividers and have a 6.6V range:
ADC0 Power Module Voltage (A2) R20=R43=10K
ADC1 Power Module Current (A3) R21=R44=10K
ADC2 (A5) R22=R45=10K
ADC3 (A4) R23=R46=10K
Therefore input impedance on all Navio2 ADC inputs is 20K
I am wondering if the voltage drops to 50mV because the input impedance (20K) is far below than the PM output impedance (100K).
I tried to connect my current sense wire to ADC0 input instead of ADC1, same result, I also tried another DF13 harness.
For further references I measured the Pixhawk current sense input impedance, it shows 1M which is correct according to the schematics.
Of course I may have done some mistakes so any comments would be appreciated.
