Warning : Although an antenna record was located in the RINEX file, no phase centre information could be found in the IGS/NGS file for your antenna. Estimated height should be used with caution. Ensure that both the antenna type and the RINEX header record "ANT # / TYPE " are valid.
It is a bit frustrating that the error messages are not necesarily very specific: What to make of
Most likely causes are not enough epochs OR missing data types.
In this case, I think it was the date type part and the PPP service got confused about the mention of “C2 L2 D2 S2” in the # / TYPE OF OBSERV line n the Rinex header.
I got another email from NRCan PPP service with the following error message:
Error : Unable to process your submitted RINEX file. The problem will be investigated and you will be informed by e-mail.
Despite this message, they still included the Rapid location report identical to one they sent in the previous email. A bit weird, but I may be informed via email on what is going on as the error message states.
I am running a RENIX log this weekend for submission to NRCAN PPP as well. This is an exploration for me and I appreciate you posting your experience trying to use their processing tools with Reach RS data. Will let you know how I make out. I am located very close to the 49th in the foothills of the Rockies.
